Page 76 of 92 FirstFirst ... 266672737475767778798086 ... LastLast
Results 1,126 to 1,140 of 1369
Thread: Post Your Recent REJECTIONS!
  1. #1126
    Dec 2011
    Florida
    @ manny we worked so hard on it :(,Wonder why it got rejected for Copy Right,Reject reason: size grainy soft info centered level category copyright
  2. #1127
    Dec 2011
    Florida
    Reject reason: quality size grainy soft overexposed contrast centered copyright Should i Delete The jet center in this one? i think i did Over Edit it But i wanted to see what The screeners would say,I dont know why Copyright is on there..:( Thanks for help Manny By the way
  3. #1128
    Senior Member Cary's Avatar
    Quote Originally Posted by Just_Lucas View Post
    Like I said before, you can't have your own watermark in there.
    General Photography - Website | Instagram
    PlaneCaptures - Website | Instagram
  4. #1129
    Dec 2011
    Florida
    oh haha sorry i didn't see it if you told me before thanks
    Quote Originally Posted by Cary View Post
  5. #1130
    Senior Member Chris102's Avatar
    Pennsylvania
    This one was rejected for being overexposed. I really don't think it is, so I may appeal this. Thoughts?
  6. #1131
    There is a clear spike in the levels at the right side of the histogram, and to my eye it also looks like it lacks contrast. Do you have an original, unedited version?
  7. #1132
    Hard to tell with a small image, but it does look a little bright on the fuselage forward/below the cockpit windows and again behind the cockpit over the door. The detail looks washed out there, but again, it could be the small image I'm looking at.
  8. #1133
    Pennsylvania
    Any thoughts on this one? They rejected it because they said it needed CCW rotation, but I don't see it. It's leveled on the horizon.
    http://www.airliners.net/addphotos/r...2_mpo_4758.jpg
  9. #1134
    Quote Originally Posted by Chris102 View Post
    It's probably worth appealing that one. The water tower sides are virtually square to the sides of the picture. I think they are letting the crooked windsock and other pole on the right, influence their judgment. If you appeal, note that those two are crooked in real life, and that the water tower is level. Architectural features/buildings (which need to be built level) always trump lightpoles/windsocks/etc.
  10. #1135
    Pennsylvania
    Thanks for your advice, Cary. I just appealed it and I'll keep you updated!
    EDIT: Accepted!
  11. #1136
    Senior Member JDANDO's Avatar
    Oct 2009
    KMSP, KANE
    EDIT: Accepted!
    Yeah. always nice when an appeal is accepted.
    Need some guidance on this jp.net reject.
    here are the "similar" ones
    http://www.jetphotos.net/viewphoto.p...7423684&nseq=0
    http://www.jetphotos.net/viewphoto.p...7411091&nseq=1
    Thanks,
    I thought noses/tails were different that full-one shots?
  12. #1137
    Jeremy, typically same side same approach is considered similar enough (or not dissimilar enough) and you could agree that we see the same image technically in your close up. Although if the dates are different, technically it should be ok. What was the exact reason for rejection?
  13. #1138
    Oct 2009
    KMSP, KANE
    It was rejected for similar. It bugs me, since it typically does not give me the same image at the same airport note.
  14. #1139
  15. #1140
    Quote Originally Posted by JDANDO View Post
    If it makes you feel any better, I just made the same mistake :) Although I thought mine were definitely dissimilar enough, it is same side and so it was rejected.
