+ Reply to Thread
Results 1 to 6 of 6
Thread: 787 Question
    787 Question
    Check this shot with the equalizer on:
    Note the exhaust that seems to be squirting out of a hole on the sides of the engine. Anyone have any idea what this is?
    I noticed something coming out of roughly the same spot on the engines during the taxi tests...
    Senior Producer / Chief Correspondent, NYCAviation
    Always available at jeremy@nycaviation.com
    Re: 787 Question
    since the airplane is all-electric the engine might be producing too much power for taxi and takeoff than what would normally be required. in the airplanes we've come to know to this day, a lot of power is robbed from the engines by the bleeds to operate the packs and anti-icing.
    that's my guess, i haven't seen the pic as i'm stuck at work at the moment.
    Re: 787 Question
    Jeremy, which engines are on that 787? The G5 uses the Rolls Royce engines, and I noticed that on the ground while taxiing. So I asked a mechanic about that and they said Rolls Royce knows that there will be a bit of overfill in the engine oil, so instead of it burning inside the engine, this is a vent from the oil catch area. Keeps the engines cleaner on the inside, and serves it's purpose. He said to worry if you don't see some smoke/vapor there.
    Administrator GothamSpotter's Avatar
    Re: 787 Question
    Those are RR engines. First GEnx 787 hasn't flown yet.
    Re: 787 Question
    That is correct. I think just 5 & 6 have them.
    NLovis
    Guest
    Re: 787 Question
    Yea that flow is normal on R&R engines. 757 R&R engines do that. 777 R&R same thing. Same goes for the 747 R$R and the A340 R&R engines. Its a vapor vent for the burnt oil.
+ Reply to Thread
