@ manny we worked so hard on it :(,Wonder why it got rejected for Copy Right,Reject reason: size grainy soft info centered level category copyright
Reject reason: quality size grainy soft overexposed contrast centered copyright Should i Delete The jet center in this one? i think i did Over Edit it But i wanted to see what The screeners would say,I dont know why Copyright is on there..:( Thanks for help Manny By the way
Photography - http://caryliao.com
Aviation Photography - http://aeropx.com
Diecast Models - http://diecastwings.com
This one was rejected for being overexposed. I really don't think it is, so I may appeal this. Thoughts?
There is a clear spike in the levels at the right side of the histogram, and to my eye it also looks like it lacks contrast. Do you have an original, unedited version?
Hard to tell with a small image, but it does look a little bright on the fuselage forward/below the cockpit windows and again behind the cockpit over the door. The detail looks washed out there, but again, it could be the small image I'm looking at.
Any thoughts on this one? They rejected it because they said it needed CCW rotation, but I don't see it. It's leveled on the horizon.
http://www.airliners.net/addphotos/r...2_mpo_4758.jpg
It's probably worth appealing that one. The water tower sides are virtually square to the sides of the picture. I think they are letting the crooked windsock and other pole on the right, influence their judgment. If you appeal, note that those two are crooked in real life, and that the water tower is level. Architectural features/buildings (which need to be built level) always trump lightpoles/windsocks/etc.
Thanks for your advice, Cary. I just appealed it and I'll keep you updated!
EDIT: Accepted!![]()
Yeah. always nice when an appeal is accepted.
Need some guidance on this jp.net reject.
here are the "similar" ones
http://www.jetphotos.net/viewphoto.p...7423684&nseq=0
http://www.jetphotos.net/viewphoto.p...7411091&nseq=1
Thanks,
I thought noses/tails were different that full-one shots?
Jeremy, typically same side same approach is considered similar enough (or not dissimilar enough) and you could agree that we see the same image technically in your close up. Although if the dates are different, technically it should be ok. What was the exact reason for rejection?
Any thoughts on this one? Rejected for "dark."
http://www.airliners.net/addphotos/r...avp_4987_2.jpg
