(RARE) Beech 2000A Starship 1 Close-Up HD Walk Around - Rockford AirFest 2014
This walkaround is truly a rarity as only eleven were made and only nine are active according to the FAA. Only five are privately-owned and airworthy. I am most grateful to the folks who flew this one in so we could all enjoy it and photograph it. I have seen a few of these before and have seen several flying overhead even but this is I think the closest I've been in quite some time.
There are almost no pictures anywhere of this particular reg# number as a Starship as it is quite new to this aircraft. Formerly the reg number, N903SC, belonged to a Hawker Siddeley HS125 but that airplane has since been retired it seems. This pressurized twin-turboprop 6-8 passenger business aircraft is driven by Pratt & Whitney Canada PT6A-76A engines each having 1,200 SHP. The propellers are 5 bladed McCauley's and are 8ft 8 in in diameter.
Originally meant to be a replacement for the King Air, known as Preliminary Design 330 (PD330), the carbon fiber composite airframe and canard design made this a ground-breaking airplane and it continues to turn heads today.
This great article and videos by my friends over at Airlinereporter.com, http://www.airlinereporter.com/tag/beechcraft-starship/
http://www.youtube.com/watch?v=iM6V0TxKjaE
gives a good overview.
This aircraft has a crew of 1, a length of 46.1ft, wingspan of 54.5ft, height 12.9ft, empty weight of 10,085 lb. and a gross of 15,010 lb or so. Max t/o weight is 14,900 lb. Max speed is 385 mph 620 km/h, 335 knts with a cruise of 353 mph or 307 kts. it has a range of 1,576 mi (1,370 nm) and a service ceiling of FL410 (RVSM certified).
Rockford Airfest 2014
Chicago Rockford International Airport KRFD / RFD
Saturday June 7th, 2014
This video is the property of O'HareAviation Plane Spotting & Flight Tracking.
It may not be used in any way without permission.
ORD AIRPORT WATCH
Chicago O'Hare Airport Crime Prevention Unit / Bensenville Police Dept.
Planespotting from Chicago O'Hare International Airport KORD / ORD 2014
© O'HareAviation 2014
Tags for this Thread
- You may not post replies
- You may not edit your posts
Forum Rules
