Hello...
I was wondering if anyone can shed some light on some great spotting locations at ATL besides the Renaissance Hotel?
Thank you![]()
Hello...
Thank you![]()
not a CLUE about ATL but there's a nice spotting park at PDK if you want private stuff...its been pretty busy when I was down there with our airplanes.
Point A: Renaissance Concourse Hotel
Directions: From downtown Atlanta, take I-85 south until exit 73 for Virginia Avenue. Make a left on Virginia Avenue, and then a quick right onto Toffie Terrace. Hotel will be on the right.
Security: You will have to purchase a room for the night, and spotting is encouraged. They even have a "Plane Spotting Package" for a small fee.
Photography: For planes that sit across the street from the hotel (parked and not moving), 100-180mm should get the job done, and longer lenses can give you a close up on the nose. For landings, you'll need about 200-300mm, especially for the CRJs. For takeoffs, 250-400mm will cover you here.
Notes: Very nice hotel, and I had a great time there. Each room has its own balcony as well. Make sure to request an airport facing room.
Point B: South Parking Garage
Directions: From downtown Atlanta, take I-85 south until exit 72 for Camp Creek Parkway and Atlanta Airport. Make a slight right at S Terminal parking, and follow signs to the south parking garage.
Security: You will have to obtain permission from ATL's landside operations department.
Photography: 50-100mm should be more than enough for taxis and 100-250mm for departures and arrivals on the 9s. If 27s are in use, you will get a "blue sky" shot at takeoffs, and may need 200-300mm.
Notes: There is a small fee for parking in the garage.
Point C: Sewage Treatment Plant
Directions: From downtown Atlanta, take I-85 south until exit 238B for I-285W/ATL Airport. Keep right at the fork, and follow signs for Clark Howell Hwy/Loop Road. Keep right at the fork, and continue to merge onto Airport Loop Road. Continue to Lake Mirror Road.
Security: This is not public property, so carry your ID and if asked to leave, do so.
Photography: Good shots of 27L arrivals. For full framed shots, you'll want about 220+mm of zoom.
Notes: Make sure planes are landing 27s.
Try those to start
EDIT: Here are some more: http://flightlineaviationmedia.com/p...s/airport-atl/
Adam Sheinhaus
