Page 78 of 92 FirstFirst ... 286874757677787980818288 ... LastLast
Results 1,156 to 1,170 of 1369
  1. #1156
    I wouldn't waste time appealing it... rather edit it again... bring down the exposure a bit and bump up the contrast a bit ... play with it a little and find the right combo. Findthe brightest while in the fuselage and measure it with the eye dropper to be no more than 240-250 level. Measure the blacks on the darkest part of the tire and see that it is close to zero level... perhaps 5 or so :-)
    May look a bit more acceptable to the screeners.
  2. #1157
  3. #1158
    Senior Member Cal07's Avatar
    Jul 2012
    Queens NY
    Reject reason: editing halos soft overexposed editing personal
    Reject reason: editing halos overexposed editing personal...
    Air Jamaica was approved on JP.net...guess its not to Airliners.net standards...
  4. #1159
    If you are using the shadow/highlight selection in photoshop it will do that. I try not to use that feature.
  5. #1160
    Akie, to me, the tops of both fuselages, and the vertical stabilizer on the South African are blown out. Much too overexposed.
  6. #1161
    Jul 2012
    Queens NY
    Quote Originally Posted by Zee71 View Post
    Mark thanks, i'll try and not use that feature.
  7. #1162
    Jul 2012
    Queens NY
    i was thinking that when was uploading, but i was using the histogram reading...
  8. #1163
    Pennsylvania
    Thanks, Manny, for the help with the Learjet.
    This one was rejected for being unlevel, but my Photoshop ruler shows it as level when measured from underneath the 727 to the nose of the Spanish A310.
    http://www.airliners.net/addphotos/r...51swf_5488.jpg
  9. #1164
    Senior Member Cary's Avatar
    Quote Originally Posted by Chris102 View Post
    Using that tarmac/grass edge for leveling will only work if the tarmac/grass line is exactly perpendicular to your lens. It does have a little bit of "needs CCW rotation" look to it, but I don't know what you'd base your leveling on. Maybe the nose gear strut at 100%. Looks very minor though...maybe .1 to .2 CCW.
  10. #1165
    Too much red/yellow - personal color.
  11. #1166
    Mark, your photo was probably realistic for the lighting situation, but A.net probably wants something more like this:
    I just played with the Color Balance in PS, but if you have a RAW file and can change WB/Tint, that would be easier.
  12. #1167
    Quote Originally Posted by Cary View Post
    Trust him, he knows...
  13. #1168
  14. #1169
    Agreed Chris... it looks too CW ... add a bit of CCW and be done ... awesome shot!!
  15. #1170
    Mark, it's more like
